Kirjoittaja Aihe: TomTom Go ........ 9.465 New firmware  (Luettu 14698 kertaa)
« : 17.02.2012 kello on 17:45 »
Juuri tässä hiihtoloman alla ajattelin tsekata Tomppaan päivitykset - tuli Western&EasternEurope -kartta, mutta tuli uus firmiskin 9.400 GO 930T:hen. Kas, ulkoasukin hieman muuttui  ???
Ovatkos muut päivittäneet?
Change log found:
Version 9.400
GO Classic, ONE, ONE-S, XL 335 LE/ SE/SE-TM, XL 350, XXL 550, START 40/ 45/ 50/ 55, GO 920, 720, GO 730, 930, 630, RIDER, RIDER2, ONE XL, ONE XL S, GO 300, GO 740 LIVE, EASE, ONEv3/ 3rd edition, ONEv2/ new edition)
All supported devices now have an improved status bar with different tabs similar to most recent devices, and a clearer indication of the speed limit.
The Speed Cameras service has the following improvements:
You are now warned about speed cameras with new, clearer icons.
You can now report and delete speed cameras with one touch.
You can now confirm that a speed camera is stillthere.
When driving in an average speed check zone, your average speed is now displayed.
If you have a LIVE device and a valid subscription, speed camera locations, both fixed and mobile, are now delivered over-the-air.
We have improved the explanation about the data you share with TomTom, and the settings required for you to give permission and share data from your device. *
TomTom Buddies and sending and receiving files from your device using Bluetooth are no longer supported.
The TomTom HD Traffic receiver is also no longer supported. The receiver was only available in the Netherlands. When downloading this software, the TomTom HD Traffic receiver will no longer be compatible with the device. If you want to continue using the HD Traffic receiver, you must not download this software.
GO 520/720/920: if you download a new map after installing this update you will be upgraded to a map that supports addresses in Greek and Russian.
If you use your device at about the same time every day your device will find your current location faster when you first start your device. This improvement is for all compatible devices exceptes the GOx20 and GOx30 devices, and LIVE devices which get QuickGPSfix over the air.
Various performance improvements and bug fixes have been implemented.
En löytänyt vars. nakkilaattori-topikkia, niinpä pukkasin tänne  8)
« Viimeksi muokattu: 5.04.2012 kello on 09:24 »
  • Viimeksi paikalla:eilen kello 16:10
Vs: TomTom Go ........ 9.400 New firmware
« Vastaus #1 : 17.02.2012 kello on 18:24 »
Mulla on tuo sama kone ja päivitin sen joskus viikko sitten. Silloin en huomannut mitään uutta. Täytyypä kattoo huomenissa jos vaikka mullekin...
Ps. Niin, se tietenkin että poisti Ranskan kamerat ja ilmoitti niiden laittomuudesta.
    • Matkailuvinkkejä
« Vastaus #2 : 17.02.2012 kello on 19:07 »
Niinhän tuo näkyi päivittyvän, mitään uutta en tosin huomannut.
Minulla on GO 950T
Lisäys
Nyt ei enää käynnisty kun saa virtaa.
Lisäksi kyselee onko nopeusvalvontakamer a kohdallaan. >:(
« Viimeksi muokattu: 18.02.2012 kello on 15:54 »
« Vastaus #3 : 17.02.2012 kello on 21:58 »
Oiskohan 950:ssä tuoreempi softa..
Nyt 930:ssä:
  • Uuden näköinen ja värinen (läpinäkyvä) pikavalikko
  • Nopeus ennen eripaikassa kuin kello
  • Valikkopalkki pilkottu 3-osaiseksi + pyöristykset. Yksiköt pienellä ja eri väriset. Uudelleen reititys -palkki ei piilota kuin tämän keskimmäisen (ennen koko alapalkin). Tästä muuten vaihtuu 2D/3D (ennen hankalasti valikoista mutkien takaa)
  • Reittitietoja enempi
  • Tasavärin tilalle liukuja ja läpinäkyvyyttä
Monta muutakin eroa, esim. yhteenvetokartalle nyt myös liikennetiedot - nämä pisti silmään ilman oikeaa käyttämistä
    • Matkailuvinkkejä
« Vastaus #4 : 18.02.2012 kello on 16:02 »
Varmaankin, koska äkkiä havaittavia ulkonäkömuutoksia en havainnut.
« Vastaus #5 : 18.02.2012 kello on 18:23 »
No jeps, minäkin sain uuden ilmeen Tomppaan. Päivittelin lisää myös niitä KP:ta, joita Homen kautta saa. Näyttää vaan että SFC-yönylipaikat on tyhjä. En ainakaan löydä siitä muuta kuin pelkän kuvakkeen????
    • Matkailuvinkkejä
« Vastaus #6 : 19.02.2012 kello on 11:08 »
Niinpä näkyy olevan, siinä tiedostossa on jotain vialla, se ei ole oikea POI tiedosto.
  • Viimeksi paikalla:tänään kello 00:56
  • Häme
« Vastaus #7 : 19.02.2012 kello on 19:03 »
Päivitin eilen XL:n uusille kartoille. ohjelman muutoksessa en havainnut mitään näkyvää muutosta nopealla silmäilyllä. Käytössä sitten näkee, minkälaisia muutoksia on tullut.
Vanha One 3rd edition Skandinavia ei uutta ohjelmaa saanut, vaikka kartat päivitinkin ajan tasalle.
  • Vs: TomTom Go ........ 9.400 New firmware
    « Vastaus #8 : 19.02.2012 kello on 19:34 »
    Puolitoista vuotta vanhan XXL:n kartta päivittyi Eastern Europe v885...versioksi ohjelmiston muuttuessa sitten juurikin tuollaiseksi kuin 88k5 mainitsi ja niin teki myös ohjelmiston suhteen viisi vuotta vanha GO720.
    Käytännössä päivityksen huomaa helpoiten siitä että 2D/3D vaihto onnistuu "lennosta" ja kameratolpan tullessa kohdalle sen kuvake on muuttunut siten että sen sijainnin voi ilmoittaa sitä kameratolpan kuvaketta painamalla.
    Vs: TomTom Go ........ 9.401 New(2) firmware
    « Vastaus #9 : 1.03.2012 kello on 09:37 »
    Jaas 9.400 ei ollut ihan bugiton, koska latautui äsken uudempi versio 9.401  :-X
    Ja jotainhan taas resetoituu, kotisijainti, kotinumero, ..
    « Vastaus #10 : 1.03.2012 kello on 10:22 »
    Nätti tuli vanhasta 920:kin päivittämällä, pitää viel ostaa uus karttapäivitys.....
  • Vs: TomTom Go ........ 9.401 New(2) firmware
    « Vastaus #11 : 1.03.2012 kello on 10:35 »
    Kannattaa tuo 12 kuukauden karttapäivitys jättää keväämmälle niin saa uuden kartan vielä vuoden -13 kesälle, noin minä ainakin teen, tiedä sitten milloin ne kartat uusiutuvat loppujen lopuksi.
    « Vastaus #12 : 1.03.2012 kello on 10:40 »
    Mutta, sen (12kk karttapäivityksen) saa ostettua vain viimeisimpään karttaan - ei siis monta vuotta vanhaan. Eli ensiksi pitää päivittää kartta ajantasalle, ja siihen päälle tuo..
    EDIT; ts. kuten tietokoneohjelmisto puolella 12kk karttapäivitys (=ylläpitosopimus, Subscription) on "ennakko-ostos" tulevista päivitysversioista hivenen halvemmalla kuin vars. version julkaisuajankohtana - eli softatalon "rahoittamista"  :-\
    « Viimeksi muokattu: 1.03.2012 kello on 10:47 »
    « Vastaus #13 : 1.03.2012 kello on 10:50 »
    Mulla loppui ed. karttapäivitys viime joulukuussa, ajattelin uuven ottaa tuos kesän korvalla ennekuin suuntaamma Ruotsin & Tanskan kautta Hollantiin.....pitä is käyä Rotterdamissa
    « Vastaus #14 : 1.03.2012 kello on 12:50 »
    Noinhan se tosiaan oli ettei kartan parane olla ikäloppu mutta ilmeisesti ei tarvitse olla sitten viimeistä huutoakaan, mun viime päivityksestä on lähes kaksi vuotta ja nyt meinasin sitten ottaa pelkän päivityksen, mutta nyt iskikin epäilys siitä että pitäisiköhän se päivittää nyt samoin tein ettei kartta vanhene liiaksi. ::)
