Kirjoittaja Aihe: Problem with aquaflex heater  (Luettu 2286 kertaa)
  • Viimeksi paikalla: 8.11.2026 kello on 14:35
« : 30.10.2026 kello on 17:01 »
Hello fellow troubleshooters!
I've hit a bit of a dead end and could really use some help or guidance from someone more experienced.
The issue is with my Primus AQWE6 (Aquaflex). It has stopped working. It attempts to ignite, but then shuts itself down completely (I'll attach a video).
The gas bottle is full, and both the fridge and cooker are working perfectly. Before disconnecting the gas valve pipe, I could see and hear that gas was reaching it as well.
I measured the resistance of the gas valve solenoids, and the readings matched the specifications I found online. You can also hear the valve opening in the video.
The power supply is 13V and remains stable throughout the entire ignition cycle.
The same applies to the ignition system: power reaches the ignition module and remains stable throughout the whole cycle.
All wiring between the gas valve module and the control panel is intact.
I also checked the PCB on the gas valve module, and couldn't find any broken connections or damaged tracks.
At this point, I'm not quite sure where to go next.
How can I verify that gas is actually passing through the valve?
How should I check the ignition electrode and flame sensor? It's not possible to visually see whether a spark is being generated. Is there any way to test this?
Am I overlooking something important? Has anyone experienced a similar issue?
Could someone point me towards an older discussion thread that might be relevant?
Thanks in advance for any help!
Vs: Problem with aquaflex heater
« Vastaus #1 : 30.10.2026 kello on 17:03 »
Sorry, I couldn't attach the video here, but the ignition process lasts for approximately 6 seconds. After that, the entire system shuts down and the red warning light on the control panel comes on.
  • Viimeksi paikalla:tänään kello 08:39
« Vastaus #2 : 30.10.2026 kello on 17:15 »
Here are link other chain: https://karavaanari.org/index.php/topic,30938.0/topicseen.html
« Vastaus #3 : 30.10.2026 kello on 22:56 »
Onko liekkivahtijohto kiinni. Oletko tehnyt jotain lämmittimelle?
« Vastaus #4 : 30.10.2026 kello on 23:21 »
Kyllä, liekin tunnistusjohto on kytketty. En ole tehnyt lämmittimelle mitään muutoksia. Vika ilmeni yhtäkkiä.
Sytytys alkaa normaalisti, kipinä kuuluu ja kaasuvetiventtiili napsahtaa. Sytytyksen aikana jännite pysyy noin 13 voltissa. Olen myös mitannut kaasventtiilin käämien vastukset, ja ne ovat ohjearvojen mukaiset. Noin kuuden sekunnin kuluttua koko järjestelmä sammuu ja ohjauspaneeliin syttyy punainen vikavalo.
Kaasun hajua ei ole havaittavissa. Onko sinulla ajatuksia, mistä vikaa kannattaisi seuraavaksi etsiä?
« Vastaus #5 : 31.10.2026 kello on 09:52 »
Here is the video : https://youtube.com/shorts/vj2U-h7aBSs?is=LVOtM1Yztxr7Zn2c
« Vastaus #6 : 31.10.2026 kello on 10:29 »
Kaasuventtiilin liittimen alapuolella on yksi musta johto, onko se yhteydessä pannun runkoon? Käytössä voi olla mikrotemp joka on kytketty pannun oikealla sivulla ruuvilla runkoon tai sähköohjauspoksin alla olevaan purkeen. Jos ei ole yhteyttä runkoon ei kaasuventtiilin pääventtiili aukea. Kaikissa Aquaflexseissä ei ole mikrotemppiä ja silloin musta johto on kytketty vesitermostaatin kiinnitysruuvin alla.
« Vastaus #7 : 31.10.2026 kello on 11:32 »
Kyllä, oikealla puolella on runkoon kiinnitetty lämpösuoja. Vasemmalla puolella on samanlainen tyhjä reikä kuin kuvassa.
Mittaaessani lämpösuojaa sain jonkin lukeman, ja kun pidin sitä sormieni välissä ja se lämpeni, myös mitattu arvo muuttui.
Voiko olla, että mittaustulos on jotenkin väärä tai että lämpösuoja ei toimi oikein eikä siksi anna lämmittimen käynnistyä?
Mikä pitäisi olla lämpötila-anturin vastusarvo esimerkiksi 10 °C lämpötilassa?
« Vastaus #8 : 1.11.2026 kello on 11:25 »
Kävimme eilen vielä reissussa, ja yritin saada lämmityksen toimimaan, mutta tuloksetta. Irrotin kaasulämpöventtiili n moduulin, tarkistin vielä piirilevyn liitännät, mittasin kelojen resistanssit ja tarkistin venttiilien toiminnan myös mekaanisesti. Kaikki vaikutti olevan kunnossa ja venttiilit liikkuivat normaalisti. Koska en pysty näkemään, syntyykö kipinä vai missä kunnossa poltin on, laite täytyy varmaankin purkaa osiin. Mistä kohdasta järjestelmä olisi järkevintä tyhjentää?
